PLC Voltage Monitoring - HMI Display
Hi Does anyone know if AXIOLINE PLCNEXT CPU AXC F 2152 can monitor internal voltage? I would like to use it on HMI display ? Regards Daniel
Hello Daniel, I don’t see the Voltage-Value in PLCnEng 2021.0 Project, under PLC node in the PLANT Area (PLC->DEVICE_STATE) . I assume it is not implemented/available. May be it is possible to get a Voltage-Info via Item under IDeviceStatusService. I’ll clarify your Request and give you an answer at the begginnig of the year 2021. Best Regards, Eduard
Hi Eduard, Many thanks. I am looking forward for your reply. Happy New Year Regards Daniel
