PLCNext Engineer 2024.6 not working
PLCnext engineer version 2024.6 is not opening. When i tried to open it is giving the below error.
PC Name: LAPTOP-OMG18TV3
Session Start: 02/03/2026 16:21:49
Project Name: PROJECT7.pcwex
Project Path: C:\Users\contr\AppData\Roaming\PHOENIX CONTACT\PLCnext Engineer\2024.6\NEW\PROJECT7.pcwex
PLCnext Engineer, Version 2024.6 (Build 7.2.258.0, Revision 570b0d99)
Unexpected Exception
Initialization of ‘Telerik.Windows.Controls.RadTreeListView’ threw an exception.
Exception chain:
XamlParseException
XamlObjectWriterException
FileNotFoundException
Details
XamlParseException
Message:
Could not load file or assembly ‘Telerik.Licensing.Runtime, Version=1.4.6.0, Culture=neutral, PublicKeyToken=98bb5b04e55c09ef’. The system cannot find the file specified.
Stack trace:
at System.ModuleHandle.ResolveType(QCallModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)
at System.ModuleHandle.ResolveTypeHandle(Int32 typeToken, RuntimeTypeHandle typeInstantiationContext, RuntimeTypeHandle methodInstantiationContext)
at System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type genericTypeArguments, Type genericMethodArguments)
at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(MetadataToken caCtorToken, MetadataImport& scope, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, ListBuilder1& derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctorWithParameters, Boolean& isVarArg) at System.Reflection.CustomAttribute.AddCustomAttributes(ListBuilder1& attributes, RuntimeModule decoratedModule, Int32 decoratedMetadataToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, ListBuilder`1 derivedAttributes)
at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType)
at System.Resources.ManifestBasedResourceGroveler.GetNeutralResourcesLanguage(Assembly a, UltimateResourceFallbackLocation& fallbackLocation)
at System.Resources.ResourceManager.CommonAssemblyInit()
at MS.Internal.Resources.ResourceManagerWrapper.get_ResourceManager()
at MS.Internal.Resources.ResourceManagerWrapper.GetStream(String name)
at MS.Internal.AppModel.ResourcePart.EnsureResourceLocationSet()
at MS.Internal.AppModel.ResourcePart.GetStreamCore(FileMode mode, FileAccess access)
at System.IO.Packaging.PackagePart.GetStream(FileMode mode, FileAccess access)
at MS.Internal.IO.Packaging.PackagePartExtensions.GetSeekableStream(PackagePart packPart, FileMode mode, FileAccess access)
at System.IO.Packaging.PackWebResponse.CachedResponse.GetResponseStream()
at System.IO.Packaging.PackWebResponse.get_ContentType()
at MS.Internal.WpfWebRequestHelper.GetContentType(WebResponse response)
at MS.Internal.WpfWebRequestHelper.GetResponseStream(WebRequest request, ContentType& contentType)
at System.Windows.ResourceDictionary.set_Source(Uri value)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(Object inst, XamlMember property, Object value)
Please help me to resolve the error. Many of our site are running in the 2024.6 versions.
Hi jayachandra,
go to the folder where PLCnext Engineer stores the projects etc (default is: C:\Users\yourWindowsUser\Documents\PLCnext Engineer)
Remove the content in the folder “Plugins” (or rename the folder I guess)
BR
DivisionByZero
I tried several approaches earlier, but your recommendation worked perfectly.
Thank you very much for your valuable support. It is truly appreciated.
