PLCnext Engineer 2025.9 OR 2026.0 is constantly disconnecting
I was using PLCnext Engineer 2025.9, and every time I upload the project to the PLC, it disconnects when uploading or even in the middle of the upload. Several times, it got stuck on writing to the PLC. And after 10 minutes, it was still writing and not finishing. So had to kill the app. However, for some reason, it deleted the PLC from my project and saved it to my project file. SO I lost all my IO assigned variables, all the Profinet devices with their configuration, and all the parameters and assigned variables to all Profinet device addresses and their bits. Had to redo all the work again…
But what is annoying is that every time I upload code, it disconnects. Sometimes have to try several times to upload it.
PLCnext Engineer 2026.0 Disconnecting when Uploading to PLC 2025 12 11
And even when debugging and forcing some changes, like the input state.
PLCnext Engineer 2026.0 disconnects when forcing inputs 2025 12 11
And one other thing is that when I force one input, another is forced by itself (“IN_System_ToEnable”). Do not know why and how.
Hello.
Try to increase timeout and polling interval in communication settings.
BR
