Hi team, I have one question about the memory in the PLCnext. If I’m right, any PLCnext could run with or without SD card (it’s optional).
* If the PLC has SD card, all the Linux directories are mounted on SD card. (If I'm wrong, let me know it). * If the PLC has no SD card, all the Linux directories are mounted on RAM memory and tha capacity is 500Mb (in case of AXC F 2152).The question is, if I’m working without SD card, as the memory that is used is the RAM memory, is volatile? Could I lose my data by turning off and on the plc? Thanks for your support!
