PLCnext OPC UA Security Policies - Config Error
Hi Engineer, I’m new to working with PLCnext and looking to setup an OPC UA connection between my AXC F 2152 (2022.9.0) and TP6101. I’ve worked from a different engineer’s program and followed the online instructions and can successfully test the server in Visu+ but when I try and browse my endpoint, I receive a „Cannot connect to the OPC UA server…BadSecurityConfig“.
I downloaded UaExpert to help troubleshoot and when I try to add the server and target my IP address, I can see the ‚OPCUAServer@axcf2152‘ but with no offered security protocols even though I’ve enabled basic 256 and basic 256 SHA256 in the PLC. If I try to connect any way, I receive an Error ‚BadConfigurationError‘.
I’m sure I’m missing something obvious due to my inexperience and would appreciate any insight you can offer. Thanks in advance.
