I just went through the process of installing Eclipse…created a new C++ project file, copied the file to the PLCnext Engineer Libraries folder…and I get an error that it cannot be referenced. It’s version is incompatible. I just downloaded all new Eclipse, etc so everything is up to date. What the heck?
Hello lylecox,
which Firmware has your AXC F 2152 installed.
And
which Firmware did you select in your PLCnext Engineer project? You will not be able to use a 2019.9 Engineer Project with a 2019.0 PLC.
→ as it will try to configure features that are simply not included in older versions.So you will need to either Update your Hardware or use a Control Template (Select on the right side at the Network Tab-> Axioline → Control → AXC F 201X.X
You can check the FW Version of your PLC at the Web Based Management,
kind regards,
