PLCnext - PUT Method Api Rest
I need to write a variable, making use of the PLCnext rest api. Currently you can read values using the get method. The request configuration is as follows: Best regards, Sebastian Menoni
Hello Sebastian, please find the documentation, how you can write the values in PLCnextInfoCenter. I think the following MakersBlog article will be also interesting. I hope it helps, if not please give me short feedback! Best Regards Eduard
