Please give us feedback!
Dear Early Adopters, we are approaching rapidly the final phase of our early adopter program and the PLCnext Technology will soon be released to the public. This is the time to think about the future presentation of all those valuable information in this community. Therefore we ask for your feedback for this community and its forums. Do you like the discussion area? Which functionalities are missing. Every feedback is well come. Frank Walde / Markus v. Schlichtkrull
(Community admins)
Hi, please consider a print option or PDF generation function - expecially in the “Kowledge Base” section for saving helpful information. Using Mozilla, there are only blank pages to be printed - if I use the print preview. Thanks, Thomas
Hi, As a technical contact for Russian customers I would like to see a page with local community members and related forum threads. Also it would be nice to have a weekly email didgest with important updates, tips and tricks, latest community examples, books to read, etc.
Hi Thomas,
thanks for your hint, we are working on a Plugin for a direct PDF print possibility. Regards Frank
Dear PLCnext team, I have three little notes on the ports in PC Worx:
1. In PC Worx the ports are numbered from 00 to 09. On the hardware from 00 to 07 and I can’t change the port name.
2. In PC Worx it is not possible to copy the name of the ports. I can only select the name from the drop down menu and this is unsorted after a port reconnect.
3. It would be good if the port connections could be saved. After deleting and inserting a library (updating library works only sporadically) I have to reconnect all ports by hand. Regards Marcel
Hi, I’m a bit late on the post, but I have to say I really like this community. I feel it is something we have been missing as an international technical communication tool for general issues and questions on our technology. This kind of community is sending us in the right direction.
I imagine we do, but do we have mods who can move posts around into the proper forum sections? But by and large this community is great. We need to keep posts flowing and get people to visit regularly to keep it alive. I agree with Andrey that some kind of email digest sounds like a good idea to keep people engaged.
One note I noticed, On submitting a post, the OP should be auto-subscribed to email notifications. I had a post that I didn’t realize had a bunch of comments until check it much later manually. Another feature might be a “best answer” selection for the post that fixes an issue like in stack overflow.
Hi Andrew, first of all thanks for your feedback and of course we’ve a few moderators who can shift post to other categories. We’ve at the moment a more or less simple forum implementation, but we take your suggestion for our next steps of community integration. Even when it is not that advanced I guess the resolved function will already help. At every resolved post the end user is marking the “best answer” so that it is directly visible next to the Questions. Take care!
Hi everybody, I’m working on our first client project and have noticed a few smaller things in the interfaces: 1.) why is it not possible to zoom in when in the variable declaration? 2.) having the variable sheet in the POU is fine, but it would be better, if it would be possible to have the sheet floating. That would say, to un-dock the variable sheet so that we could move it to a second screen or have it accessible when working in the programming. Those changes from and to are really a waste of time. 3.) when working in SFC and defining an transition as an INLINE transition and adding the power rail, we have to move the courser before adding a contact. Could that not be automated? When a power rail has been added, the courser should move to the right side of the power rail. I also have got the first system crashes. If more then 4 to 6 POU’s or FB’s are open at the same time, the software crashes without any information. To end on a positive note: the integration of FB’s programmed in C# is working good. There are still some limitations that haven’t been documented in the help but in general it is working.
I have one addition: The AutoSave function should save in to the project. Due to the crashes from earlier today, I did miss some of my progress. The AutoSave would help but there is no way to import the missing work in to the original project - or I haven’t found that yet.
Hi Peter, nice to hear that you’re working as well with the PLCnext Engineer, and I appreciate youre feedback very. Please let me directly answer your questions and requirements: 1.) why is it not possible to zoom in when in the variable declaration?
The zooming feature is only implemented for the grafical worksheets. And therefore it is really necessary.
But I already got this requirement from other customers, so the demand and priority of this feature is increased. _2.) having the variable sheet in the POU is fine, but it would be better, if it would be possible to have the sheet floating.
That would say, to un-dock the variable sheet so that we could move it to a second screen or have it accessible when working in the programming. _
This is really a good feedback and I will take care of it when we are working on the multiple monitor solution.
Until now the only area which can be used on another monitor is the CrossFunctionArea (watchwindow etc.) 3.) when working in SFC and defining an transition as an INLINE transition and adding the power rail, we have to move the courser before adding a contact.
I forwarded this feedback directly to the responsible developer team. They will rate it and afterwards I can scedule it for one of the next versions. I also have got the first system crashes. If more then 4 to 6 POU’s or FB’s are open at the same time, the software crashes without any information.
Crashes are even the worst things which can happen. I guess youre working with a released version?
in case of crashes, please dont hesitate to send the problem reprots together with a project or a way to reproduce them to our support channel.
( I know you know the correct email adresses). So again, thx Peter for the feedback and I hope to see you in Hannover. Best regards Carsten.
Hello Peter, your feedback/requirement point 3 was so appreciated by the development team that they will
implement your suggestion for the next release version (PLCnext Engineer 2019.6). Best regards Carsten.
Hi Carsten, in every new software, we will see issues that needs to be addressed or thinks that we users would like to have. It is the nature of the beast. But over the past few days, we have seen some issues that should not be happening, as they are core functions for PLC operations. As it would be to complex to write those all down, I will have a list for you, when we meet in Hannover over the coming days. Peter
