Popup keypad (Howto force a keypad in a HTML5 Edit field)
Dear all, On a panel-pc I running a browser in kiosk mode. It shows a PLCNext HMI page. On this page there are some edit fields. When I click on that field I need to popup a keypad. It seems that browser on the panel-pc is checking the config of the pc to decide to show a keypad or not. But how do I force the browser to show a keypad on a edit field? Is there something I need to add to the URL? Is the something magic that I have to incorporate into my design of the HMI pages in PLCNext Engineer? Please help. Kind regards, Wilco
Hello, I had the same issue and found this is not supported. There is some question about whether it is even possible given the nature of HTML5. As a work around, we created a custom keypad for our customer. If you are interested I could possible share our solution to this challenge. Regards, Loren
I would be interested to hear your solution. I’ve been working toward creating a custom keypad in my free time, but have been unsuccessful thus far.
Hello Loren, I’m very interested in your solution. Please send it to me. Kind regards, Wilco
With the great example from Loren, I have made a version that does integer and reals, positive and negative. A from my perspective is also looks a bit simpler :wink: Because this version works with char code it can be extended to a full keyboard… For those who have more spare time… @Loren; please feel free to ad this to your blog Kind regards, Wilco (please adjust the extention for Keypad_3.pcwex.png to Keypad_3.pcwex)
Hi Wilco, I really like your solution and that is how it should have been done to start with. Thank you for doing this and for posting your solution. I will update my blog in the near future with your solution. I would like to put your name in the blog if that is acceptable with you? Regards, Loren
Hi Loren, That’s nice. As long we do it together, we can change the world… Kind regards, Wilco Meewis
Hi, I’m in need of a custom keypad like this for my application. I am wondering if someone can share me an example solution. (The link of the on-screen keypad project on the marker’s blog dosen’t seem to work.) Thank you, Pier-Olivier Baillargeon
It looks like Loren has updated the version number on the file. The repository linked in that article is here: https://github.com/plcnextusa/On-screen-Keypad/
