I am trying to communicate in profinet between 2 AXC F 2152 PLC’s. i am able to communicate in profinet. But, the Profinet input data is not updating the connected field Input_data instead it is updating in PND_S1_INPUTS. Please refer the below screenshots.
PNImage5.pngPNImage4.pngPNImage3.pngPNImage2.pngPNDEvice.pngpn-comm.pngPNimage1.pngHello,
one of the PLCs must be integrated as Profinet device into the PLCnext Engineer project of the other PLC.
On the “device PLC” you can use the system variables PND_S1_INPUTS and PND_S1_OUTPUTS to exchange data with the “controller PLC”.
On the “controller PLC” you can use the process data of the “device PLC” DI4096 and DQ4096
You can reach me at vishal.kumar@phoenixcontact.co.in for further queries
Please see the similar Request:
Forum - PLCnext Community (plcnext-community.net)
