Profinet Controller with AXC F 2152
Hello friends Today I tried to test the AXC F 2152 as Profinet Controller; my device is one ILC131 ETH But the ILCxxx does not show as compatible module Then, in the Local Devices I made the import of GSDML file. But the ILC131 does not appear in the list of Profinet devices
Hello The ILC PLC’s are not inplemented yet. They need a new FDCML file, witch is first released at the SPS at november.
How ever i had the same problem and got the guys at Badpyrmont to make it for the ILC131.
i have send the file/instruction to your email. - Emil Gundersen
JCJelektro.dk
Here is the files rename to .zip and unzip the inlinecontrol devices.pdf
Inlinecontrol Devices.pdf
Hello Sir, Where can I get files for ILC 151 as a Profinet device device
Hello cpranjale, You can download the GSDML file for the ILC 151 from our website - here. On the product page, click the “Download” tab (below the product picture) and you will find the GSDML file on that page. - Martin.
Dear Sir, I am Using PLCNext Engineer 2019.3 and I am Unable to do this , can you suggest way to make this happen in 2019.3 LTS
Hi Chetan, I don’t know what I was thinking when I posted my answer above … I’ll check and let you know if/where we can find the correct library for ILC 151. - Martin.
Dear Sir, For now Its very urgent at Customer end as we are migrating project frop, PC Wrox Engineer to PLC Next Engineer due to OPCUA Issues and many more things . In PLCNext Engineer 2019.3 I am not able to Import ILC 131 as provided in above library as also, it shuts down when I import above library in PLCNext Engineer , which was working with PC Worx Engineer. Kindly provide Library for ILC 131 for now Regards Chetan
Hi Chetan, I have been in touch with the product manager for PLCnext Engineer, and he has referred me to the product management team responsible for the ILCs, so I will raise this issue with them. Please understand that this is not an issue with PLCnext Engineer (or with anything related to PLCnext Technology), but I will do my best to get an answer for you. - Martin.
Hi Chetan, The answer I have just received from my colleagues responsible for ILC controllers is: “We have currently no date for an avaliable FDCML or GSDML for the ILC 1x1 as a PN device for PLCnext.” I understand that you are looking for an immediate solution for your customer. The quickest way to get a solution is probably to raise this issue directly through your subsidiary, with the people responsible for ILCs. - Martin.
