Profinet problems
I have connected a PLCnext AXC F 2152 with a IFM Al1102 master module and configured it as a Profinet communication. The PLCnext is the controller and the IFM module the device. I can find both devices but the BF-D led from the PLCnext keeps flashing red and the SF led also keeps on. On the side of the IFM module the BF led indicator is off but the SF indicator is also on.
Do I need to change some specific parameters in PLCnext engineer or is the problem somewhere else? Can someone help me with this?
Thanks in advance.
Kind regards,
Kilian
Hi Kilian,
I suggest to go to the WBM - WebBasedManagement of the AXC F 1152 and take a look into the diagnostic page.
There you can easily find all error codes and figure out, whats going wrong.
Kind regards
Carsten
