Hello
(using axc f 2152, PLCnext Engineer 2024, FW 2023.6.0 and HW 02)
I was using PBCL_SysLinuxShell_1 FB to call a pythonscript on the PLC. This worked as intended. I must have changed some settings because now I get follow error from the FB:
The only setting I remember changing was enabling the REST interface. It’s turned off again but the same notification occurs. Next I gave the python file execute permission and got this:
The first four lines of code are:
It seems as if it can’t find/ open these python packages anymore.
Is this a permission problem?
If so how exactly do I give permission to the folder which includes all the files needed?
How come it suddenly doesn’t work anymore?
Kind regards
Mathieu
