Hi, I’m trying to connect FL Switch 2308 as a Profinet device with PLCnext F2152 Ver.2020.3. I would like to read the record index of the switch, but I cannot read with RDREC error F008 “Invalid type of a parameter” as following images.
I think the parameters are right, the ID = 21(or 0x15), INDEX = 3, MLEN =2.
PNIO_CONFIG_STATUS is as following image;
The process data of the switch can be read.
The Switch is working in Profinet mode.
BF-D is blinking, BF-C is OFF and RUN is ON. Could you let me know what is wrong? Best regards,
Hello Hue, can you please attach how exactly your Setup looks like.
What Variable+Type is attached to which input / Output of the RDREC Functionblock.
Do you have the same issues with reading other index as well?
Kind regards,
Hello Hue, i think this means the index is not supported.
I have contacted the Support-Team of the Switch and asked them how to corectly read this index.
kind regards,
