RE: MQTT support
Hello team I’m starting a new project using PLCNext Enginnering with The CPU AXC F2152 and a Module converter from ModBus Serial to MQTT Broker, any advice before I start the development, or what not todo.. cheers!!!
This topic has been branched from this thread: https://www.plcnext-community.net/en/discussions-2-offcanvas/mqtt-support.html
That sounds like an interesting application. Do you have any thoughts on how (roughly) you will approach this problem? e.g. - do you plan to implement this entirely in PLCnext Engineer? - are you limited to IEC 61131-3 languages, or do you plan to use C#, C++, or any another language(s)? - Are you considering using OCI containers, e.g. on balena-engine or docker? - Will the solution simply (!) be a generic gateway application, which can be configured for many applications, or is it a project-specific solution?
