ReSyDnp3_V7009 library - missing files problem
I’d like to use the library ReSyDnp3_V7009 (https://www.plcnextstore.com/#/150) in my project (PLCnext Engineer 2020.0.1 and 2020.3). After installing the library file on the PC, there are no direct library files in the library folder but a sample project in *.pcweax format. Opening this file extracts the library files to the default paths: resy01 When opened, a message about missing files appears: resy02 An attempt to add extracted library files ReSyBasic_V7065.pcwlx , ReSyDnp3_V7009.pcwlx or ReSySystick_V7001.pcwlx to a new project results in the same message. Is there a problem with the library or with a newer version of PLCnext Engineer?
Hi Konrad, I’ve spoke with one of the ReSy specialists and it seems that in the tested PLCnext Engineer version (2019.6) were the PLCnext Controller lib already part of the project.
He’ll test this once again and he’ll leave a note in the Store. However, you can resolve this by adding manually the PLCnext Controller library (libraries → add library → PLCnext Controller) Take care Frank call 00131526
Unfortunately, the manual addition of the PLCnext Controller library adds it “on a different level” and the error still occurs. resy03
Hi Konrad, sorry, I’ve missed a very important detail. Please copy the “PLCnext Controller.pcwlx” lib from the directory “C:\\Program Files\\PHOENIX CONTACT\\PLCnext Engineer 2020.0\\Libraries” into the directory were the ReSy lib is located, in my case “C:\\Users\\Public\\Documents\\PLCnext Engineer\\Libraries”. You should now be able to compile the project , maybe a project → create new could be neceesary. Take care Frank
