RFC4072s Crash
I have noticed that sometimes when I set the stp/run switch on the PLC from run to stop and back to run again when I am online with PLCNextEng the PLC crashes.
Has someone else seen this?
I use PlcNextEng 2022.0.2 and fw 2021.6 on RFC
Br Stefan
Hello Stefan,
could you send the Output.log File for analysis, please?
I’ll create a Zendesk Ticket and contact you via E-Mail.
BR Eduard
I will do it the next time it crashes.
/Stefan
Here is the last lines in the output.log file after crash.
The project seems to be unloaded, the PLC is in stop and project name is —
Br Stefan
Output.log
Hello Stefan,
I can’t download the Output.log file. In this case, can I contact you via the Zendesk ticket system to continue support?
BR Eduard
Hello Stefan,
we have tried to reproduce the behavior, but without success. I assume the problem is caused by used FW 2021.6 or depends on the running application project. Can you update the FW and check if the problem persists, please? If the problem occurs, I need the used project to reproduce this behavoir. In this case we have to process the support via ticket system.
Thansk!
BR Eduard
You can contact me via Zendesk.
The PLC where running 2022.0.8 LTS fw, I also have another crash and I can give you that file as well.
Br Stefan
Hello Stefan,
ok we will proceed this issue in Zendesk.
BR Euard
