RS485 modbus
Hi I have a problem with a RS485UNI card. I have configured the plc as per the example it works fine for a while but every few hours I get a error on the UNI_send or UNI_RCV functions. When I deactivate and activate the function again the error is still there. The only way to get it to work is to do a power cycle! I tried to find the Warm_Restart function but it is not available!
Hello, We will need to get more information about this problem from you. Can you please send a complete description of the problem, along with the following additional information:
                                               * Which Controller you are using, including the firmware version
                                               * Which version of PLCnext Engineer you are using
                                               * Which PLCnext Engineer function block library you are using
                                               * Any other information that might be relevant, e.g. how long before the error appears
… to the following email address: automation-service@phoenixcontact.com Sorry for the trouble. ~ Martin.
