Hello, I would like to test the PLCNext RT datalogger function. I’m following the procedure found in the video linked below but I cannot find any db file at the desired path (and neither in the rest of the PLC) I tried both with FW 2020 and 2019.9 without any results, maybe I’m doing something wrong I attach my configuration file (data-logger.config)
It’s in pdf format for the upload What could be the problem? is there some log I can check? Best Regards Gianluca
Hello Oliver, the path is the same path of the config file, so it exists.
I also restarted the PLC several time… I already used the template of config file I found in the github repository. There is quite nothing to do, I double checked everything, but probably there is something that I cannot see. In which cases the datalogger won’t be created?
Hi Oliver, I’m sorry, I did not noticed that defect was a link. I removed the comment and it worked. Thank you Gianluca
