Safely storing secrets and passwords on PLCnext controllers
Hi PLCnext-Community,
we are trying to improve the security of our controllers. As it is, we are currently storing secrets on the controllers for use by our projects. For example, we need to send files to remote servers, therefore we need to store the passwords for accessing these servers.
We also would like to have a python application that has write access to the PLCs global data space. That access is password-protected (which is good), but if the python application is running on the same controllers that it is accessing, then the password also needs to be stored on that controller.
Are there any procedures or methods for storing such passwords as securely as possible?
The ideal solution would protect against an attacker with physical access. In other words: Even if an attacker were to hold the controller in their hands, they would be unable to retrieve the password from the device.
The next best level would be protection against an attacker with remote access, meaning the passwords are safe from someone that can log into the controller using SSH.
And so on…
I’m interested in any tips and opinions! What methods do you use? What level of protection is achievable?
Best regards,
Daniel
Hi Daniel,
here you can find our documentation of the security profile of the web server and the user authentication.
PLCnext Technology ‒ Info Center: Security
Best regards,
Lennart
Hi Lennart,
thank you for your response!
I am not sure that I understand how the Security Profile will help me. According to Activating the Security Profile on security.plcnext.help this will, among other things, disable SSH login.
While that certainly would make remote attacks harder, our aim is to keep remote access by SSH but still have increased protection for passwords stored on the controller.
If that is (practically) impossible, that would also be useful information.
Best regards,
Daniel
