SD-Card Applic A doesn't work
Good Day Everyone, I’m having an issue with my PLC that doesn’t want to work with the SD-Card Applic A 2 GB…apparently it has been formatted to insert a new software…but now it doesn’t want to work anymore…
Anyone can help on fixing back this sd-card? Thank you in advance. Andrew
Hi Andrew, I’m unsure which controler you are using, but I guess you’ve an AXC F 2152. Cause all PLCnext Control (like AXC F 2152) are using a Linux OS you need a memory card with ext4 file system.
Means you can not use the “old” SD cards anymore, you need a SD FLASH xGB PLCNEXT MEMORY (2GB 1043501 or 8GB 1061701). If you’re using a PC Worx 6 PLC (like ILC 1xx or AXC 1050) you’ve to take care to not format the card!
Otherwise you’ll delete the licence information and the card can not longer be used with the PLC…not Cu Frank
Hi Frank, Thank you for your support…isn’t possible to restore this information on the SD-Card? Thank you, Andrew.
Hi Andrew, it is unfortunately not possible to restore the licence, this can only be done in our dev. cu Frank
