Hi there, is it posible to insert a bigger sd-card for storage. Best regards
Hello, Currently there are two SD cards available for the PLCnext Control - 2GB and 8GB. These are the only SD cards that can be used with the PLCnext Control. If 8GB is not enough, you could try connecting a Network Accessible Storage device to the PLC. I haven’t tried this myself, but I would be interested to hear from anyone who has. Martin.
Hi Martin, thanks for the quick response.
So is it necessary to use the cards from phoenix? Stefan
Yes, absolutely. There are special files on the SD card which are necessary for the SD card to be used by a PLCnext Control. Also, if an SD card from Phoenix Contact is reformatted, it will not be possible to use it any more with a PLCnext Control. Martin.
