Sd flash 2gb memory licenses
Hi, I need your help. Working with the SD FLASH 2GB PLCNEXT MEMORY, I made a mistake. In the media/rfs/externalsd section I accidentally deleted the „licenses“ folder. How can I recover these files? (I am working with Putty and WinSCP)
Hello cris, if you format the SD or delete the original installed data manually, certain information on the SD card that is required for use with Phoenix Contact devices will be lost. After formatting or manually deleting of original installed data, you can no longer use the SD card to operate the controller. Please: • Ensure that the SD card is not formatted. • Don’t delete the original installed data (e.g. licence) • If you want to delete the overlay file system from the SD card: Reset the controller to default setting type 1." Please send the SD card back for repair. Please don’t try to restore the license data using third-party tools, under certain circumstances the acceptance of repairs may be refused! Best Regards Eduard
