If we are adding AXL F RS UNI 1H card to AXC F 2152, ttyS (serial console) option will be available or not?
If it is available then which serial console it will take, how to find out?
Since the PLC /dev is having too many tty’s by default
#attachedshould we need to map external hardware with any of the serial console for avail this option?
Then what is the procedure for that?If the ttyS (serial console) option is not available then how to change the parameter of AXL F RS UNI card using python script?
