Shell command fro PLCnext Eng
Hey Team, I hope you all doing well. back when we were at the PCworx eng we have this lib block (picture attached) , that allowed to send shell commands tp the Linux os as a buffer, is there any way to do that with PLCnext base Lib, couldn’t figure it out. thanks Untitled
Hi Yuri, I also haven’t figured out a simple way to do that. At the moment the “best” solution I’ve found is to do this from a custom-written C++ component, and trigger the command via GDS port(s). Not a nice solution, so I’d be happy to learn of anything better. Martin.
