Splitting Array for Proficloud
Hi Everyone,
I have tried everywhere to find answers to this and not getting anywhere, please can you help.
I have a PLCNext controller which has a serial data module which is collecting modbus data from a meter.
I have ticked OPCUA boxes and can read the data on UAExpert and also on Node Red.
The data is an array so am splitting the data in node red simply using payload.
But, I cannot get the data to proficloud or Ixon which is what I will be using. It seems that they don’t accept arrays. So my question is, what is the best way to split the data in PLCNext program so that I can have tags for each value of the array? Is that a possibility?
If you can help that would be great, thank you.
regards,
Greg
Hello GregWal,
do you still need help, or have you already been able to solve your problem?
I can help you further on the Node-RED side if you send me your node flow and the array once. Then I can take a look at it and support you.
Best regards
_Florian Jacob, M.A._PHOENIX CONTACT Smart Business GmbH
