ST Code shortcut: sum/subtract
Good morning,
I tryed to use the shortcut in ST code
Var += 1;
that is equal to
Var := Var +1;
but it is not accepted; is there a syntax error or the shortcut is not allowed?
The „addition assignment“ operator += is not allowed in Structured Text, at least not in PLCnext Engineer, and (I think) is not required by the IEC 61131 standard.
ST Code Objects ');\n mywindow.document.close(); \n mywindow.focus();\n setTimeout(function () {\n mywindow.print();\n mywindow.close();\n }, 1000)\n return true;\n}\r\n\r\n\r\n
