When I want to write my project to the starterkit controller it asks for authentication. I typ in the password written on de controller and as user i take Admin, but it says it failed to authenticate. Is it possible to disable authentication or to get the correct login?
Hello, please write “admin” instead. the username is case sensitive. In the WBM you can disable the Authentication for convenience. If this does not work please make sure you are using the latest FW and PLCnext Engineer. kind regards,
