Startup with the can module
Hi I’m new to the PLC world. I’m actually playing with the AXC F 2152 and the AXL F IF CAN 1H 2702668. I’m struggling to get any data from the FB. The D and the 00 led are flashing green (see the attachement video).
                                             * I find out the meaning for the D led (The station is ready to operate, communication within the station is OK. The data is not valid. The controller or higher-level network is not providing valid data. A malfunction has not occurred on the module), but I don't know how to resolve this.
                                             * What's the signification of the 00 led flashing ?
I also use the example from the can_9, I joined a screenshot of the module. I need to specify the clock frequency, the nominal bitrate and the data bitrate, where can I find those parameters ? Anyone to solve my issue please ?
Hello rajee, please see the answer from my colleagues in charge of your request:
                                             * For solving the D-LED flashing behavior you have to set an output processdata in the localbus (AXL) for it
                                             * Please have a look to the attached screenshot![](https://phoenixcontact.zendesk.com/attachments/token/UMrooqUQ6qXnNFFA1W6IFZyhe/?name=inline-1902154739.png)​
                                             * It depends from your CAN-Bus device. It has to be in the datasheet of the module for example
Best Regards, Eduard
Problem solved, Don’t really know what was the issue. I updated the firmware to the latest one and the support helped with the use of the function block.
