String variable containing Chinese characters cannot be displayed on embedded HMI web
Hello team, We are required by our customers to display some string variables containing Chinese characters on embedded HMI web, but we find that strings containing Chinese characters are displayed as a series of question marks on HMI web, which cannot be dispalyed correctly. The details can be found in the attachments. Could you please help us figure it out? Really appreciate your support.
Hello, What HMI are you using? Do you get the same problem from other devices e.g. from a browser running on a Windows PC? - Martin.
Hello, I just used my Windows PC and open a browser to display the HMI web and found this problem. I didn’t use any other HMI devices.
Hi Steyl, I’ve checked this case with a colleague of mine and I guess you’ve the problems only when the text is displayed from a string type variable and that everything is fine when you enter the text as static field. The problem is that the string is inside handled PLCnext as a pure byte stream which does not support multibyte languages (like Chinese for example). To solve this we are planning a multilanguage support for beginning of next year. Take care! Frank
Hi Steyl,\nI’ve checked this case with a colleague of mine and I guess you’ve the problems only when the text is displayed from a string type variable and that everything is fine when you enter the text as static field.\nThe problem is that the string is inside handled PLCnext as a pure byte stream which does not support multibyte languages (like Chinese for example).\nTo solve this we are planning a multilanguage support for beginning of next year.\nTake care!\nFrank
Hi can I get an update on this issue? I was trying out the multilanguage function in the simulator with the browser based hmi, and when i use swedish characters inside a string I still get question marks on the hmi-page
Best regards
Michael
Hello!
And what about WSTRING datatype? It seems that it can be used freely in this case. It displayed correctly as dynamic variable. Same for Swedish and Cyrillic characters.
Hello!</p>And what about WSTRING datatype? It seems that it can be used freely in this case. It displayed correctly as dynamic variable. Same for Swedish and Cyrillic characters.</p>[https://forum.plcnext-community.net/uploads/CYZWBN6QRP3E/png.png</a></p>[https://forum.plcnext-community.net/uploads/IN4MLU4N8SJF/png.png</a></p>
This works fine, I am using the “Alarms_1_4” library and the UDT for that library is locked so I can not change the datatype. But thanks for the tip, now atleast I might be able to do a workaround.
