Hello PxC Team,
I would appreciate your support with an issue I’m experiencing. I have SD card 1061701 , and I need help with the procedure to clean it.
When I insert it into the PLCnext 2152 , the system crashes. I suspect it’s due to the apps and settings previously loaded onto the card, but I’m currently unable to access it to perform a reset or cleanup.
Could you please guide me through the correct steps to fully clear the SD card?
Thank you in advance for your assistance.
