Hi engineers :
I'm finding out the communication problem between AXC F 2152 and Siemens S7-1200, PLCnext kit will be the server, s7-1200 will be the slave, can you support me how to communicate? I sincerely thank you.
Hi engineers :
Hello tienanhpham9910,
the simplest and most efficient communication between two PN-Controller is the PN-protocol. You can configure one Controller as PN-Master and other than PN-Device. The another way is to use the Modbus TCP communication to exchange the data via Modbus Register. BR Eduard
Thank Mr.Eduard !
Can you help me with Modbus TCP problem or is there any document related to connecting these two controllers? I sincerely thank you
You Can Use Modbus TCP IP Library from PLC Next Store.
In that you can Make Your PLC NExt as a Modbus TCP Client or Server as per your Requirement. You Can Connect me Over harshid@digitech-solution.co.in
