The transport protocol is not supported
Hi everyone!
I am facing problem in configuring OPC UA - Client . In my Command Prompt the error message is red as follows: „09:28:30.568Z :client_tcp_transport :47 [NODE-OPCUA-E05] this transport protocol is not supported :ocp.tcp:“. Hope someone can help me to fix this error! Thanks very much!
To help narrow down the source of the problem:
Are you able to connect to the OPC UA server using UaExpert from Unified Automation?
Are you able to connect to other OPC UA servers using the same client software?
It looks like there is a typo in your URL. The error message says that ocp.tcp is not supported. The protocol is spelled opc.tcp. Please check the URL in your OPC UA client.
