TO_TIME Conversion giving negative values
Having some issues with the TO_TIME() function I’m getting negative values and the wrong values on some of the values.
when i activate my function to convert the int values to time values, two of the variables get the wrong value like this:
after.pngAnd before i activate the function the default values are like this:
before_.pngIs this a bug or a feature? anyone got any ideas?
Might it be the swedish characters in the variables… :slight_smile:
Best regards
Mike
Hi!
You faced with datatype overflow when multiply integer variable before type conversion.
изображение.pngYou should provide explicit conversion of datatype before operation and/or use exact constant declaration (implicit type conversion)
изображение.pngBest regards.
Thank you for the quick response! It works now.
