Tutorial for the OPC UA Server
Hi, is there somewhere a manual or tutorial for the OPC UA Server on the AXC F 2152? How can I start it an write or subscribe values with UaExpert? Greetings Johannes
Hello, it usually is already enabled.
Unfortunatly there is no official guide about this topic released yet. You have to explicitly disable it in PC Worx Engineer if you dont want to use it.
You are able to connect with many different encryption login mechanisms.
The Anonymous and no encyption mode is disabled by default. First add the Server. Select a ecryption+ login method I used Basic 256 sign& encrypt. Open Server and loggin with admin user or another user you created with WBM add your vars from address Space to the Data access view…
My Program Instance Name is “JLog” Usually All variables are introduced as OPC variables.
