Udp communication
Hello All,
My self-Jagadeesh I am facing a problem that I am having three controllers AXC F 2152 version 00/2024.0.0, Each controller having unique Ip Address, Now I have to send data from controller1 to controller2, So I am using UDP socket_2, UDP send_2 and UDP receive_2. In Controller 1 UDP socket_2 is used, and its handle out is taken as variable and assigned to UDP send_2 fb and controller 2 Ip is taken as DEST_IP at the UDP_send_2 the controller 1 data is 16character as transferring to the Ip address at parameter DATA in fb and assigned to a variable data type is WSTRING with initial value “” at IN/OUT of the DATA parameter. Created a new project for controller 2 and used UDP receive_2 and data are receiving at DATA parameter of the fb to a variable data type is WSTRING with initial value “” at IN/OUT. But the length of the characters is 13. Send data is 16-character string but received 13-character string.
Please Help me with this.
Thank You in Advance
Hi Jagadeesh,
Thank you very much for your question. As we need to understand your requirement more in detail, I am assigning this call to the business unit in India and the team will be in touch with you shortly
