Unable to locate Data Logger Sessions?
So this is a bit odd: I can’t seem to locate the Data Logger Sessions page. On my PLCnext node I only have the ‚Tasks and Events‘, ‚Port list‘ and ‚Online Parameters‘ tabs. Is there something missing like a checkbox somewhere? Thanks in advance.
What version of PLCnext Engineer are you using?
And, what PLC type and firmware version are you using in your PLCnext Engineer project? PLCnext Engineer knows that PLCs with older firmware versions don’t include the data logger function, and so it does not display this tab for those PLC versions. Solution: Upgrade the PLC to the latest firmware version, and use the same PLC firmware version in the PLCnext Engineer project.
