We got a AXC-F-2152 controller a few years ago. I’m starting to use the controller again. I’m running in to the problem that it’s running a very early firmware (1.1.0.23). In the WBM I do not have the options to update the firmware like described via the WBM. In the WBM I can only see General Data and User Manager. I would like to update the controller to the latest firmware. Does someone have the instruction or a way to update to the latest version?
The procedure is described in the PLCnext Info Center:
Hello Martin,
Thanks a lot! This worked perfect for me!
I do want to point out there wasn’t a *.exe file after unzipping. But will work fine when you skip the 3rd and 4rd step.
