Used controller: AXC F 2152 Which possibilities do we have for uploading files towards a SFTP server? The source file is stored locally on the PLC.
* The IT library for PLCnext Engineer only supports FTP
* The PLCnext Base library for PLCnext Engineer only supports FTP
* Curl only supports FTP out of the box
Is there a way to extend curl with SFTP functionality? (like described here: https://www.techrepublic.com/article/how-to-build-curl-with-sftp-support/) Any other possibility?
Hi Sven, sftp is installed with FW 2020.6.1, at least:
[](mailto:admin@axcf2152:/opt/plcnext$)admin@axcf2152:/opt/plcnext$ sftp
> usage: sftp [-46aCfpqrv] [-B buffer_size] [-b batchfile] [-c cipher]
> [-D sftp_server_path] [-F ssh_config] [-i identity_file]
> [-J destination] [-l limit] [-o ssh_option] [-P port]
> [-R num_requests] [-S program] [-s subsystem | sftp_server]
> destination
… so you could try this with the Shell FB from the PLCnextBase library? ~ Martin.
