Use the SD Card to load new recipe?
Hi If we set the SD card as: Support external SD card not check: -Can we use other SD card then Phoenix Contact SD Card? -Can we have access to SD card using advance language (Python)? -Can you give us the path to access the SD card? Customer has no access to internet, no Ethernet link to PLC, he would like to send SD card to customer to update recipe.
Hi Dominick, [quote]If we set the SD card as: Support external SD card not check: - Can we use other SD card then Phoenix Contact SD Card?[/quote]No (sorry). [quote]- Can we have access to SD card using advance language (Python)?[/quote]No (sorry) [quote]- Can you give us the path to access the SD card?[/quote](see above - sorry!) Only PLCnext SD cards are supported in PLCnext Controllers, and we only support the use of these cards when the „Support External SD card“ option is enabled. In addition, as described in the User Manual, these SD cards can only be inserted and removed when the PLC is powered off.
