User account to login via SFTP, datalogger directory only
So we have a datalogger session running and are also making use of Proficloud.
Now the researcher likes Proficloud/Grafana but needs the raw data and the CSV files coming from the dashboard’s panels is processed data… not the raw data. If there’s a way to download the raw data from the Proficloud, please let me know – we haven’t found it, yet.
We have the datalogger session, writing to an SD card as a back-up. But if they want the raw data, they could get it by using WinSCP and downloading the SQLite files over SFTP.
Instead of using the admin account I would like to give them a dedicated account just for this.
So I’ve tried making a user account via SSH/PuTTY, and that was no problem. But whatever we do, the access keeps being denied. Have reset the password and still not working. The Linux OS of PLCnext is custom… is this impossible or is it possible? How can we make this possible; a user account that can be used to login via SFTP to get the datalogger folder and restrict it’s access to that directory only?
You can access raw Proficloud data through the REST API:
Technical Documentation | Proficloud.io In this documentation are the general structure and concepts of Proficloud.io described.
For more questions about Proficloud, please use the Contact form on the Proficloud website:
Contact | Proficloud.io Do you have any questions about Proficloud.io, Smart Services or generally want more information about us and what we do? Just get in touch!
For the user account, does it work if you add the new user through the Web-Based Management page?
Security - User Authentication If user authentication is enabled, authentication with a user name and password is required for access to certain components of the controller and certain functions in PLCnext Engineer.
You can access raw Proficloud data through the REST API:</p>[https://proficloud.io/technical-documentation/#apis-services</a></p>For more questions about Proficloud, please use the Contact form on the Proficloud website:</p>[https://proficloud.io/contact/</a></p>For the user account, does it work if you add the new user through the Web-Based Management page?</p>[https://www.plcnext.help/te/WBM/Security_User_authentication.htm</a></p>
Hi Martin,
Thanks for the info. I hope there would have been an easier way to access the raw data within Proficloud.
Will look into this later. Then for now they will have to download the data from the SD-card if they want the raw data.
As for the user account, no that doesn’t work. I’ve just tried it again with a complete new admin account. The accounts you create here via the WBM are not created for the SSH service.
_As for the user account, no that doesn 't work. I’ve just tried it again with a complete new admin account. The accounts you create here via the WBM are not created for the SSH service._I just used WBM to create a new user account with admin rights, and I was able to use those new user credentials to log in the the PLC using ssh.
I’m using an AXC F 2152 with FW 2023.0.
