Hi Can we install this on the PLCnext AXC 2152? https://www.ge.com/digital/sites/default/files/download_assets/proficy-historian-edge-from-ge-digital-datasheet.pdf Did someone at Phoenix Contact has experience with this.
Hello, [attachment]07-05-_2021_10-43-31.jpg[/attachment] having a look at the Requirements it doesnt look like it is supported. AXCF2152 1 . arm not x86 2. not 1GB RAM 3. not 8 GB Storage. You will moslikely have to switch to a AXC F 3152 minimum
Does the EPC 15x2 might be a better solution?
The EPC would seem to match the specs. Are you able to try it?
