Hello, do you know how to perform dynamic variable exchange? So that when I copy and paste a screen, I don’t need to change the variable of all the items one by one.
Hello Barbarra
There is not a method currently in Visu+ do streamline this process dynamically. One possible solution, however, is to use Alias’s on your screens and use Parameter files to move data into the Alias’s. In this method, it would remove the need to copy and paste to change the variables, rather you would use the same variables and move values in and out when a screen is loaded.
