I’m looking for a way to create a delay in my code without stopping the rest of the code in this time frame. It has to work as follows. If a condition is true for X amount of seconds, set the alarm bool High. The code below is a part of code where I set the alarms but there needs to be a delay.
I'm very new to C# so try to dumb it down a bit, maybe a small example or links.
I also check there but i cant understand some things: https://www.plcnext.help/te/Programming/Csharp/Csharp_in_PLCnext.htm[url="https://www.ourmarriagedate.com/"]mehndi[/url]
if (Valve.Parameter.NormallyOpen == false)
if (Valve.Status.Output == true & Valve.Status.Opened == false)
Valve.Alarm.NotOpened = true;
if (Valve.Status.Output == false & Valve.Status.Closed == false)
Valve.Alarm.NotClosed = true;
Some background info: this will be a valve control block in PLCNext written in C#. The control block should give a alarm if the valve is send open but does not give open feedback within X seconds (takes time to open).
using System;
using System.Threading;
using System.Iec61131Lib;
using Iec61131.Engineering.Prototypes.Types;
using Iec61131.Engineering.Prototypes.Variables;
using Iec61131.Engineering.Prototypes.Methods;
using Iec61131.Engineering.Prototypes.Common;
namespace EclrFirmwareLibrary1
[FunctionBlock]
public class Valve_Test
[InOut]
public Valve Valve;
[Output]
public bool Output;
double seconds = 1.00; // 1 Second Interval
[Initialization]
public void __Init()
// TODO: Initialize the variables of the function block here
[Execution]
public void __Process()
Valve.Status.Interlock = Valve.Control.Interlock;
Valve.Status.Opened = Valve.Control.FB_Open;
Valve.Status.Closed = Valve.Control.FB_Closed;
if (Valve.Control.Manual_Mode == true){
Valve.Status.Manual_Mode = true;
Valve.Status.Auto_Mode = false;
if (Valve.Control.Auto_Mode == true & Valve.Control.Manual_Mode == false){
Valve.Status.Manual_Mode = false;
Valve.Status.Auto_Mode = true;
if(Valve.Status.Interlock == false & Valve.Alarm.General == false)
if (Valve.Status.Manual_Mode & Valve.Control.Manual_Control)
Output = true;
Valve.Status.Output = true;
else if (Valve.Status.Auto_Mode & Valve.Control.Auto_Control)
Output = true;
else
Output = false;
Valve.Status.Output = false;
else
Output = false;
//Alarms---------------------------------------------------
var startTimeSpan = TimeSpan.Zero;
var periodTimeSpan = TimeSpan.FromSeconds(seconds);
var timer = new System.Threading.Timer((e) =>
CheckValve();
}, null, startTimeSpan, periodTimeSpan);
private void CheckValve()
else
if (Valve.Status.Output == false & Valve.Status.Opened == false)
if (Valve.Status.Output == true & Valve.Status.Closed == false)
if (Valve.Status.Opened == true & Valve.Status.Closed == true)
Valve.Alarm.OpenedAndClosed = true;
if (Valve.Alarm.NotClosed || Valve.Alarm.NotOpened || Valve.Alarm.OpenedAndClosed)
Valve.Alarm.General = true;
