Which ports are used by PLCnext Engineer to communicate with the controller?
Hi, I would like to have PLCnext Engineer communicate with our AXCF 2152 remotely, thus not being on the same subnet. Am planning to use ssh port forwarding, and I was wondering which TCP/IP and/or UDP ports PLCnext Engineer uses to communicate with the controller. Thanks (from my home office :slight_smile: Gideon
Hello, PLCnext Engineer uses port 41100. A list of common ports used by PLCnext Control devices are listing in the Info Center, here: https://www.plcnext.help/te/WBM/Security_Firewall.htm (see the “Basic Rules” section in “Configuring the firewall”) Hope this helps. ~ Martin.
