AXC2152 fw 2025.6, frequent disconnections (MSG_ONL0050 Connection Lost)
I have a great deal of experience from 3152, and it has never happened to me that I get disconnected from the device.
Now I am developing a project on the 2152 (HW 6), and as the project is still buggy and causes some exceptions, I did not expect that to cause disconnections like this:
image.pngI am also being disconnected from the new WBM, but that one is reconnecting rapidly on its own.
It is quite difficult to perform debugging in debug mode when the connection is lost after a few seconds.
My PC is connected directly to the PLC and a continuous ping command running in the background show no problems when i am being disconnected.
Output.log in the plc seem to be quite old, so I suppose there is a change in log save location in this fw?
Hi fluxmodel,
you could increase the timeout in Options->Online->Communication Settings, reconnect to the PLC and see if that makes a difference.
BR
DivisionByZero
Regarding the log file:
image.pngSource: https://www.plcnext.help/Changes_2025_part_2.htm
Hi fluxmodel,</p>you could increase the timeout in Options->Online->Communication Settings, reconnect to the PLC and see if that makes a difference.</p>BR</p>DivisionByZero</p>
Thanks, setting it to the next step (16 s) helped I have had no disconnections since.
Also Thanks to Martin for pointing out the log file changes. I was quite sure that I have read something about it somewhere earlier :slight_smile:
