How to configure AXCF 2152 as Modbus TCP Server
Is there a way to configure the AXC F 2152 controller as a Modbus TCP server without using the function blocks in the Modbuc_TCP library? I want to configure the controller as a server, similar to how you can configure the controller as a client by adding the „Modbus TCP Client Rev, xx“ from the COMPONENTS to the PLANT.Again, I am wondering if this is possible without using function blocks.I am currently using PLCnext Engineer 2025.0.2, and firmware version of the controller is 2025.0.2 (25.0.2.92)Thank you
