Issue installing Node-RED for PLCnext ARM version 3.0.2.4
Necessary information:
* PLC used : PLCnext AXC F2152
* Firmware : 2023.6.0
* Trying to install Node-RED for PLCnext ARM version 3.0.2.4
* Modules connected to the PLC : AXL F DI8/1 DO8/1 1H , AXL F AI2 AO2 1H
* Profinet : AXL F BK PN connected to it is : AXL F DI8/1 DO8/1 1H
* Programming software : PLCnext Engineer 2024.0.3
When trying to install Node-RED for PLCnext ARM, i encountered a strange issue. Before installing, the user partition memory usage is 2% only. Below is all the utilization parameters.
As seen, there is more than enough space to install Node-RED for PLCnext. I followed the procedure of installing the the file from the app store. It installs normally, until reaching 80% where it interrupts the installation. And shows the warnings below:
Its worth mentioning that when the installation reaches 80%, only around 30% of the user partition memory is utilized. Meaning there is enough space for the file to be installed. After interrupting the installation the user partition utilization goes back from 30% to 2%. So basically it says there is no enough space when there is space.
I would be so grateful to receive any sort of a possible solution to this issue.
Thanks.
As seen, there is more than enough space to install Node-RED for PLCnext.It looks like there’s less than 500 MB available before the installation. On the app page in the PLCnext Store, it says:
image.pngI think that might explain the problem, but to be sure you could check with the app developers using the „contact“ button on the app page in the PLCnext Store.
