Pcwlx library not built
I began to make myself familiar with „Creating functions and function block libraries written in C++“, „Creating a Shared Native Library project with the PLCnext CLI“:
Functions and functions blocks
This feature is based on Shared Native Libraries and is a combination of C++ implementation and C# wrapper. The PLCnext Technology Toolchain supports Shared Native Libraries with a Microsoft® Visual Studio® IDE template, or on the command line via the PLCnext CLI.
I followed the procedure described in the link provided for my own ‚snfunction‘, in Windows®. Contrary to the description „:arrow_right_hook: A *.pcwlx library is being stored in the bin directory of the C++ project“, no pcwlx file appears anywhere after running the command plcncli build all, despite it says „Successfully built the project Standard_FB for target AXCF3152,25.6.0.40“. Looking around, I came across this section in the file Standard_FB\Standard_FBCSharp\Standard_FBCSharp.csproj:
 <PropertyGroup>
   <!-- Build templates for the native interfaces -->
   <CreateNativeInterfaces>true</CreateNativeInterfaces>
   <!-- Build the Firmware library for PLCnext Engineer (*.pcwlx) -->
   <CreateEngineeringLibrary>false</CreateEngineeringLibrary>
   <PLCnCLIProjectType>snproject</PLCnCLIProjectType>
   <EclrProjectName>Standard_FB</EclrProjectName>
   <MinCliVersion>22.3.0</MinCliVersion>
  </PropertyGroup>
Could <CreateEngineeringLibrary>false be the culprit? I could of course simply change the false to true and try again, but I’d like to know why building the library doesn’t work out of the box.
Addendum: Changing <CreateEngineeringLibrary>false to true didn’t help.
Try this command:
plcncli deploy
… after the build command.
Thanks a lot, Martin, that did it - the pcwlx file is now there in bin!
It’s a shame that the instructions don’t mention this essential step.
Yes, I mentioned this to the Documentation team and they have already fixed it on the website.
