Dear Expert.
I’m Downloaded POWER CONTROL UNIT LIBRARY from PLCnext Store.
I Opened example project but have many error with Library.
Please support to me.
Many Thank
After opening .pcweax file the libraries included in this project were unpacked to the specified libraries folder.
You need to enter this folder and you will find there, among others, files:
image.pngYou need to create new folder, name it „PLCnextBase_1_6_4“ and put files „PLCnextBase.pcwlx“ and „PLCnextBaseServices.pcwlx“ into it.
The goal is to have structure like that:
It should help.
Hello,</p>After opening .pcweax file the libraries included in this project were unpacked to the specified libraries folder.</p>You need to enter this folder and you will find there, among others, files:</p>[https://forum.plcnext-community.net/uploads/WTB5HMLBY44Y/image.png</a></p>You need to create new folder, name it „PLCnextBase_1_6_4“ and put files „PLCnextBase.pcwlx“ and „PLCnextBaseServices.pcwlx“ into it.</p>The goal is to have structure like that:</p>[https://forum.plcnext-community.net/uploads/O8AL6HLTELMH/image.png</a></p>It should help.</p>
Dear Sir/Madam.
Thank for you feedback.
Can I a question PLCnextBase_1_6_4 is the same path with library or same path with project?
Best
In should be in the libraries folder that is configured in PLCnext Engineer options.
In my case:
In should be in the libraries folder that is configured in PLCnext Engineer options.</p>In my case:</p>[https://forum.plcnext-community.net/uploads/3OJENT2M9NVQ/image.png</a></p>
Dear Sir.
Actuall, My default setting is like you guide.
But it was still erroe.
Do you have in the location C:\Users\Acer\Documents\PLCnext Engineer\Libraries:
* file „PLCnextBase_1_6_4.pcwlx“?
* folder „PLCnextBase_1_6_4“ with files „PLCnextBase.pcwlx“ and „PLCnextBaseServices.pcwlx“?
If 2x yes, and you still have an error like in the first post, please try to delete highlighted library from the project and then add it to the project again manualy by „Add User Library“ option.
You could simply hover over the error in COMPONENTS/Libraries and the tool tip will tell you where it expects the missing libraries to be.
Btw: I get 9 compile errors after resolving the library issue on my system (PLCnext Engineer 2025.0):
SEM1190: The specified IEC type ‚ConnectInfo‘ is inaccessible.
